1974 MT-250, finally fired it up after a complete rebuild. Bike last ran sometime in the 90s.
It will start and idle nicely. It seems to pull strong until 5,000 RPM where it just falls flat on its face, Doesn't matter if it is part throttle or full throttle.
Does this sound like a carb. issue or timing or something else?
Carb. was freshly rebuilt before it went back on, the rebuild kit came with a 120 main jet but I was able to clean up the 115 Main jet that was originally in the carb. before rebuilding it and re-installed it.
Ignition timing was set with calibrated eyeballs and a feeler gauge as I do not have a timing light here to use. It was initially too advanced as it was kicking back a lot on the starter and backfiring and I backed it off a little bit and it starts right away seems to run pretty well until it hits that 5,000 RPM wall.
Where should I look to correct this? I am a 4-stroke, fuel injected electronic ignition kind of guy so I am used to setting air fuel ratios and timing on a laptop, not with a screwdriver. Any help or direction is much appreciated.
Thanks!
And a video in case anyone is interested:
http://youtu.be/_PJMQhTaGdU
