1974 CR125 False Neutral?? http://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=12453 |
Author: | JCR17 [ Sun Dec 16, 2018 7:06 pm ] |
Post subject: | 1974 CR125 False Neutral?? |
I've been having issues going into a false neutral when down shifting on my 1974 CR125. I have the cases split now trying to find the problem. Any assistance/suggestions would be greatly appreciated...Thanks |
Author: | Endo58L [ Mon Dec 17, 2018 4:18 pm ] |
Post subject: | Re: 1974 CR125 False Neutral?? |
Check for rounded corners on the gear dogs and slots where they engage together and check for bent shift forks that have wear marks from the gears rubbing on them. I also had one shift drum with a chip in the channel that affected the shift fork travel. I switched to a steel MT125 shift lever instead of the CR125 aluminum lever to absorb some of the shock to the transmission from hard falls and collisions. |
