Hello once again Elsie Brothers, I'm getting close to finish of my 76 CR250M and having problems getting period rear shocks first had a nice set of molholland's but couldn't get parts for them was needing the top stem guide which broken in disassembley I will post pictures of them, next I order a set off Ebay and one had a bent stem causing the top guide to wear oblong and the bottom stem seal housing to wear down on one side due to bent stem. I need top stem guide and bottom stem seal housing for this set. I will post picture of them as well. if anyone can help me out it that would be great. thanks in advance for any help.
Attachments: |
File comment: Here is diagram of shock needing #7 , #16 , bottom part of #13 or #9
File comment: here is the shock I need the top stem guide and lower stem seal housing
File comment: here are the Molholland shock id I need parts for
File comment: needing top stem guide for this molholland and top seal
