crack in d.i.d. http://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=4155 |
Author: | mitchie [ Wed Oct 02, 2013 12:31 pm ] |
Post subject: | Re: crack in d.i.d. |
My rear D.I.D. and my spare rear D.I.D. both have worse cracks than that and have never given me any problems. I treat them like crap and they keep on turning. I wouldn't worry about it at all. |
Author: | SLASH [ Wed Oct 02, 2013 12:56 pm ] |
thats good to know......unfortunatly, I have found other problems recently.........missing 1 spoke, 2 others bent,a few more loose,(all right side) rim is well out of true and almost all old spokes frozen, LARGE flat spot at crack which is on both sides and now that I have tire off, I see that crack is at factory seam. fairly sure this rim is not worth $$'s for new spokes, trueing etc and hopes that it will stay together.............maybe save hub and rest is destin for pop can factory................. |
Author: | b-joe [ Thu Oct 03, 2013 12:18 pm ] |
SLASH wrote: I see that crack is at factory seam. always at the seam. |
Author: | SLASH [ Thu Oct 03, 2013 4:00 pm ] |
is it prone to flat spotting there as well? |
Author: | mitchie [ Fri Oct 04, 2013 3:31 pm ] |
Unless you are a restroration guy, your best bet is often just to buy a second used wheel. I got my spare for $40. It too had a crack, but it was straight and had all its spokes. |
Author: | SLASH [ Fri Oct 04, 2013 3:51 pm ] |
thanks mitch I am going down that road....I have an 81 xr500 wheel arriving early next week. looks as if it will work. same axle and hub#'s, different seal to occomodate 81's axle mounted speedo mini gear box. got it for $55.00 shipped. wont be out much if I cant get it to work. |
Author: | SLASH [ Thu Oct 10, 2013 7:04 am ] |
the 81 xr500 wheel, does not fit. still on the look out for an 80 rim...........new update: I have found a correct wheel with new tire. |
Author: | dogger315 [ Tue Oct 15, 2013 8:24 pm ] |
Those DIDs can be repaired to look and perform like new. All that's needed is to TIG weld the crack on both sides, then grind and sand it smooth. To bring back the original look and protection, send the RIM to TCR for clear anodizing. That process will duplicate the original clear satin finish. If you're going for the OE look, finish up the job with a repro DID rim decal. For the later 80s look, Gold anodization can be swapped for the clear. That's the process Honda used on their works bikes. I have done this to dozens of these rims without a problem. dogger |
Author: | SLASH [ Wed Oct 16, 2013 6:17 am ] | |||
Post subject: | Re: crack in d.i.d. | |||
nice to know, thanks. this is going to be a rider, here is a little before and after so far.
