Hi everyone,
I’ve recently acquired an MT250 and I’m in full tear down mode during the “off season” here in the great white north! I’ve got the bike stripped right down to the frame and I’m starting to clean and replace/repair parts. Although the bike is in fairly good shape, I’m noticing a few items that I could use some advice from other MT250 owners.
Condition: The bike was stored inside a shed, and although some of the parts have surface rust it’s not too bad, both cosmetically and wear/tear of components. I’m not doing a show quality type restoration here and it’s not my only set of two wheels, but I’d like a fun little bike for in town that’s reliable and clean, so here are my questions/concerns:
1) The bike has 3,000 miles on the odo. I’ve taken the top half of the engine apart, cleaned the piston and ordered new rings. The previous rings were very brittle and the lower ring snapped during removal as it was wedged in its groove. The top piston ring was capable of expanding and contracting, the bottom one was stuck. Everything in the lower half of the engine looks good (no leaks from what I can see) and the crank moves freely without making any noises or complaints during rotation. The engine is completely out of the frame (on the work bench) and I had originally planned a full rebuild but I’m not eager to crack the case if not needed. My other bikes (Ninja 1000, R1200S) are newer (age not mileage) so I’m not sure if the main seal and bearings are something that you’d typically replace due to age (passage of time) or whether the low mileage and visual inspection results can be relied upon and could save me some work here? Part of me says “do it while the bike is in pieces”, the other part says “don’t fix it if it’s not broken”. For those who’ve cracked the lower case, did you acquire a special tool, build your own or…something else?
2) The previous owner removed the battery, the kill switch and the rectifier and re-wired the headlight to provide power from the engine to the other accessories and lights. I’ve worked through the wiring diagram and managed to re-wire the bike back to the stock layout, including ordering a rectifier and NOS kill switch/headlight combo (most expensive replacement so far!). The only wiring question that I can’t resolve relates to the neutral switch. I can locate the head of the neutral switch, but what I can’t figure out from that diagram or other source (aka google) is how the wire (light green/red – hanging with the wiring harness that comes from the stator) attaches to the neutral switch? From what I can see it looks like the wire just sits (or gets pressed) between the switch and the case? In the parts diagrams it shows this wire as “free hanging” without any lead or attachment, and after looking around the switch I don’t see a connector hanging anywhere (i.e. matching stripped wire ends), and I don’t think the MT uses a rubber style cap since it’s tucked away behind the cover. Any help on this would be much appreciated!
3) With only 3,000 miles on the rear shocks and no surface rust or obvious leaks is there any reason to ditch them? Are aftermarket options, like progressive springs ($300), any better? I've read a few threads/posts on as they crack at the eyelets. I’m not expecting an Ohlins or Wilburs quality ride, but wondering if this is going to be “sub-par” regardless of the shock…which would support keeping the stockers.
New parts so far include: -tires and tubes - petcock valve - kill switch / light combo - rectifier - battery - engine gasket kit - new piston rings (0.25 oversize) - carb rebuild kit - various hoses - key - rear brake switch - lots of evapo-rust! The tank was holding gas from (19??) it poured out like brown sludge and I was convinced there was more stuck in the tank until I realized the remaining sludge was actually a thick coating of rust. Several electrolysis sessions and treatments of evapo-rust and the tank is in good shape (no leaks, just the petcock needed replacement).
Still needed: - Turn signals (front and rear) - Rear shocks (see question #3) - New seat cover - Air filter - ??? – we’ll see in the spring!
