85 86 CR500 right side clutch cover and water pump housing http://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=4612 |
Author: | mlwbob [ Sat Mar 19, 2016 5:15 pm ] |
Post subject: | 85 86 CR500 right side clutch cover and water pump housing |
I have an 86 CR500 in fantastic shape I just bought from the original owner. Unfortunately it sat for years and the water and coolant mixture turned into a corrosive mess (this is a common mishap for these) and ate up a good portion of the case. Does anyone have any ideas on where I can locate an NOS piece? It's the same for both 85 and 86 and is listed as part number 11340-KA5-690 I believe. Any thoughts or ideas other than EBay are much appreciated. |
Author: | brett campbell [ Mon Mar 21, 2016 6:07 am ] |
Post subject: | Re: 85 86 CR500 right side clutch cover and water pump housi |
Contact Terry at Western Honda Cincinnati 513-662-7759 and get him to check his inventory and run a parts locator if he doesn't have it. Ebay and Ebay UK is a good place to look also. You may have to buy a used one. A corroded cover can be repaired too. Love them or hate them, ebay is a great resource. |
Author: | Milloperator [ Mon Mar 20, 2017 3:09 pm ] |
You can use a 2001 CR 500R. Just Google to see the parts you need to go with it. Its all aluminum and will not rot out like the magnesium one. Or buy a use one and use engine ice coolant that does not attack magnesium. Milloperator |
