It is currently Fri Feb 22, 2019 9:59 pm
 Post subject: Elsinore 250 piston CH ?
PostPosted: Tue Mar 21, 2017 1:57 pm
Hi all
Ive researched Wossner piston 8152DA standard bore 70mm , info says compression height is 32mm
- is that CH measured from the wrist pin centre to the crown or is it from above the pin hole to crown ???
- also is the 1975 - 80 Elsinore piston CH the same ??? it would seem a possible variable thru the yrs
I dont have a piston in hand , cheers
