Suzuki RM125 1976 engine
http://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=29&t=4079
Author:  narrowfarm [ Fri Jun 07, 2013 11:03 am ]
Post subject:  Suzuki RM125 1976 engine
Hello , does anyne know if I could put a 1977 RM125 crankshaft, connecting rod and piston, with the 1977 cylinder and head onto a1 976 RM125 caee. I beleive the bottom ends were all the same from 1976-1978. The 1976 did use a different crank and cylinder compared to the 1977 and 1978 RM125.
Thanks, any deas??? john
Author:  b-joe [ Sat Jun 08, 2013 12:47 pm ]
Post subject:  Re: Suzuki RM125 1976 engine
1976, Bore x stroke: 56.0 x 50.0 mm
1977 on, Bore x stroke: 54.0 x 54.0 mm
cause of the different stroke the cases might be not intercangeable.
Author:  Axceler8r [ Tue Jul 09, 2013 6:00 pm ]
I believe you could use the cases from a '76A and the crank, top end from a '77B. The '77 RM100B is basically a sleeved down '76A. B-joe is correct that the bore & stroke are different, but if you are using the '77B crank and top end, it should work.
