2000 kx 250 transmission/sprocket trouble help please
http://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=30&t=2881
Author:  devans [ Sun Nov 28, 2010 7:18 pm ]
Post subject:  2000 kx 250 transmission/sprocket trouble help please
i just bought a 00 kx250 and split the case to clean out and make sure everything wus alright because the top end blew up and the piston broke and had metal inside so i cleaned it out and everything looked fine. then i put all of the gears back together in the transmission and sealed the case back up but now the shaft where the sprocket goes doesnt spin freely at all when its in neutral and if i do spin it with pliers then the gears inside dont seem to line up and it wont shift into any gear... do i just need to finish the assembly with the top and bottom end and ride it to have everything fall in place better or is there something wrong that it wont spin? is there a certain timing process i have to do with the gears, drum, and forks or what could be the problem any help would b appreciated thanks. i can try and give more info if needed
