timing 82' maico 490? http://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=34&t=2010 |
Author: | sm7482 [ Wed Sep 03, 2008 4:04 pm ] |
Post subject: | timing 82' maico 490? |
how do i time an 82 maico 490? it still has original motoplat inner rotor system. |
Author: | Bigmaico [ Mon Oct 13, 2008 4:33 pm ] |
Post subject: | Re: timing 82' maico 490? |
First off you will need dial indicator. Insert the dial indicator & find top dead center & set the dial to zero,then back off the dial indicator 2.1mm. you should see that the lines on the rotor & stator line up, if not loosen the 3 screws on the backing plate & line them up. once you do this & tighten the screw double check you settings. |
