http://vintagedirtbikeforums.alp-sys.com/
any montesa guys out there???
http://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=35&t=607
Author:  richter [ Wed Mar 16, 2005 9:57 pm ]
Post subject:  any montesa guys out there???
lets hear from some montesa guys!!
Author:  Proformance cycle [ Thu Mar 17, 2005 1:15 pm ]
Post subject:  Montesa guy here
Richter
Lee here:
I have a Montesa Cota 348 and a 247 Both trilas bikes. I'm in the process of locating a Grey Ghost Cappra 250!
How bout you? Montesas?
Lee
Author:  richter [ Thu Mar 17, 2005 8:31 pm ]
Post subject:  my montesa's
hi, well my stable as of now goes like this:
73 250vr cappra not restored yet
74 250 vr cappra i ahrma vintage race
76 250 va cappra i ahrma pv race
77 125 vb cappra restored
78 250 cappra purchased new by me in 1979
78 360 cappra unrestored and not deliverd till next month
81 349 cota restored
250 cappra converted to 81 h-6 enduro is my current winter project.
i really enjoy finding them and bringing them back to life. they are reliable and fast! the cota is very challenging to ride... it is much better than i am!
Author:  buzz349 [ Wed Apr 13, 2005 10:03 pm ]
I just picked up a 1980 Cota 349 and could use some ignition repair tips and a good used gas tank!
Author:  andy [ Mon May 09, 2005 1:21 pm ]
Post subject:  cota 349
hi, i've got a 349, did my second trial on saturday bike is sweet as a nut apart from oil leaking from drive sprocket (any solutions welcome).very tractable engine and seems to attract alot of attention at events.
Author:  richter [ Mon May 09, 2005 8:40 pm ]
Post subject:  349 leaking sprocket
assuming the bearing inside the case is good and is holding the shaft properly there is nothing else but seals. if your bike has a pressed on sprocket on a taperd shaft with a nut you have one seal to deal with. if your sprocket has splines and a press off clip and just slides off the shaft you have the seal in the case and a seal or o-ring behind the sleeve that is behind the sprocket on the shaft. also make sure it is not the kick shaft seal or a crack in the case below and in front of the kick shaft seal. if the mag case has been cracked from the kick start lever going to far it can crack the cases bad enough to let gear oil seep out. more than one of my montesa's have had this problem.
rick
Author:  danielsanchez [ Mon Jan 21, 2008 4:20 pm ]
Post subject:  Re: any montesa guys out there???
Hi! I´m new in the forum from Spain .I have got a 74" cota 25 "and a 74 "cota 123"
Author:  danielsanchez [ Mon Jan 21, 2008 4:23 pm ]
some pics:
Author:  danielsanchez [ Mon Jun 09, 2008 3:05 pm ]
This is my cota 25 restoration gallery,i hope you enjoy it.
http://www.kodakgallery.com/BrowsePhoto ... 356&page=1
Author:  danielsanchez [ Mon Jun 09, 2008 3:13 pm ]
1974 cota 123 ,my second montesa project.
