Casey,
why does the bike want to be so lean?
It really doesn't - it just doesn't want to be super rich, as apparently it was (a mixture rich enough to significantly reduce power doesn't always create blubbering / smoking / etc.) The question is, why is it so rich that you could drop five main jet sizes (120, 118, 115, 112, 110) and not totally starve the motor at WOT?
My vote is for a worn needle & needle jet - every one of these carbs I've encountered had that problem, to varying degrees - but it could also be other things as well (float height, float valve, leaks, etc.). A good visual inspection of the needle and needle jet orifice (with the main jet out, obviously) would be a good start. New MT250 needle/needle jet sets (16012-358-004 / -014 / -024 etc.) are very lean and fit together closely, with no ovality and little clearance. It's also possible a leaking choke circuit could be the cause. If it were my bike I'd also run it briefly without the air boot to the airbox to eliminate everything upstream of the carb (on the MT that's a
lot of stuff) as suspects. Once the cause of the richness has been eliminated, I'd go back up to at least a 120 main jet.
It's great the problem's been isolated to a rich carb mixture, one of the easier problems to deal with.
