It is currently Fri Jan 18, 2019 7:16 pm
 Post subject: Exhaust pipe collar
PostPosted: Mon May 28, 2018 1:18 pm
Hi,
I'm re-installing the stock exhaust pipe for a 1975 MT250. I bought a new OEM gasket (GASKET, EX. PIPE 18352-358-000) and NOS collar (COLLAR, EX. PIPE 18325-358-303).
https://www.nospartsnow.com/nos-honda-m ... 5-358-303/
The NOS collar is tapered and I want to be positive which side faces into the pipe and which side faces the gasket (& engine). I can't find any information on this anywhere. Has anybody installed this same piece?
A or B?
 Post subject: Re: Exhaust pipe collar
PostPosted: Mon May 28, 2018 6:18 pm
The exhaust ring fits into the pipe inlet flange as shown in your picture 'A1', with the chamfer facing out. The end of the exhaust manifold has a matching chamfer, and the white ring gasket will end up sandwiched between these two chamfers. The MR175 has a very similar setup, except the ring & gasket are combined into a single chamfered ring.
Here's how I've installed these setups, with no leakage yet - it's important to have the pipe ready to go on, with all brackets on, nuts handy, etc:
1) Clean everything well, especially the pipe flange and manifold 'piston ring' groove
2) Apply hi-temp sealant to the inner pipe flange and metal ring, and insert it till it bottoms (chamfer out)
3) If the manifold is off, use the same sealant & Honda gasket to install it on the engine
4) Install the manifold 'piston ring' (not shown in your photos) into the manifold groove after coating it and the groove
5) Coat the manifold spigot and white ring gasket, then install the gasket on the manifold end
6) Coat the inside of the pipe flange, then carefully slide it straight onto the manifold
7) While keeping the pipe in place, put on the rear bracket nut loosely to hold up the far pipe end
8 ) Push the pipe onto the manifold firmly while installing both springs
9) While still keeping most of the pipe weight off the manifold end, install & tighten all mounts
You might want to try a dry run first, as the manifold / piston ring / gasket can be a little tricky to force into the pipe flange,
and it can be hard to tell if the pipe is bottomed fully onto the manifold. These pipes are heavy and have significant backpressure,
so they chafe and eventually start leaking unless sealant is used everywhere. With sealant, they neither leak nor chafe.
PostPosted: Mon May 28, 2018 8:49 pm
Ray,
Thank you very much. This is extremely helpful.
I have not taken off the current pipe, which the previous owner installed. The manifold is already there, connecting the current pipe. When I remove that pipe, will I need to replace the 'piston ring' also? I only got new parts from the muffler side, # 5 & 7.
Do I also need to replace, on the manifold side, #13? Is that the piston ring you refer to? I don't want to make the switch until I have all the parts I need.
When you say coat the ring and manifold groove, you are still referring to the high temp sealant?
PostPosted: Tue May 29, 2018 6:06 am
I don't think you'll need to replace the #13 piston ring unless it's missing. Also, if the manifold seems clear inside I wouldn't remove it, so you shouldn't need the #14 manifold gasket either. FWIW, I've replaced the piston ring with a hi-temp O-ring on my MR175 manifold; it degrades with time, but in conjunction with the sealant continues to seal fine.
Yes, all the 'coating' I mentioned was with hi-temp sealant (usually silicone based). I used to assemble the pipes dry, and they either leaked immediately or within a few months of use. It also makes for easier disassembly later, as the sealant is much softer than baked-on carbon.
PostPosted: Tue May 29, 2018 9:12 am
Thank you, Ray.
PostPosted: Fri Aug 10, 2018 3:16 pm
Michaels wrote:
Hi,
A or B?
Part number 5 is only listed for 74's, and used up to frame serial number 1002746 only see pic. The pipe in your picture appears to have an existing beveled section made into it, do not use 18325-358-303. Just my opinion.
PostPosted: Fri Aug 10, 2018 6:20 pm
IMO the metal ring's 'OD bevel' shown in pic B1 (as opposed to the inner ID chamfer/bevel) is designed to fit into the pipe flange's ID bevel you mentioned, for a better seal there and more lengthwise 'crush' on the white gasket against the manifold bevel. It should work without the metal ring - especially with sealant - but if I had the ring I'd definitely use it, fwiw.
PostPosted: Fri Aug 10, 2018 7:15 pm
Hello Ray, I'm using the original graphite/steel mesh gaskets which are pretty tuff, that being said I have to fight these pipes on both of my bikes just to get the studs into the tabs on the muffler. Neither of them have ever leaked a drop yet, do not ride them much either. Ordered some of those new soft white ones to try. Will report back if they make things easier to assemble.
Mark
PostPosted: Fri Aug 10, 2018 7:35 pm
One thing I've done was to leave the shock bolt a little loose so the rear mount could move a little. It might also help to heat the rubber on both mounts with a heat gun on low, just to get that last bit of flex to help get the studs in.
I'm using a new mesh ring gasket on my MR now. I worked it into the pipe flange with the manifold quite a bit to get it pre-shaped to fit the pipe & manifold bevels before mounting, and it still needed a lot of pressure to align with the frame mounts. Thankfully they're pretty durable.
