It is currently Sun Nov 10, 2024 1:42 pm
 Post subject: timing 82' maico 490?
PostPosted: Wed Sep 03, 2008 4:04 pm
how do i time an 82 maico 490? it still has original motoplat inner rotor system.
PostPosted: Mon Oct 13, 2008 4:33 pm
First off you will need dial indicator.
Insert the dial indicator & find top dead center & set the dial to zero,then back off the dial indicator 2.1mm. you should see that the lines on the rotor & stator line up, if not loosen the 3 screws on the backing plate & line them up. once you do this & tighten the screw double check you settings.
