It is currently Sat Aug 16, 2025 8:03 am
PostPosted: Wed Oct 05, 2011 12:29 pm
how hard is it to convert a mt250 to a CR or mr 250? What is a mr in relation to the other two? :?
PostPosted: Wed Oct 05, 2011 7:20 pm
Different bikes... so not easy and why bother?! but yes, you can run the engines in other frames, but the MR is more like the 75/76 CR and the MT is more like a 73/74 CR from my memory...
PostPosted: Thu Oct 06, 2011 1:29 pm
There is performance to be gained by swapping a CR250 top end onto the MT250 lower. I don't think the MR will swap.
You will need the 1973-74 cylinder, head,piston, intake, carb & exhaust. All of these parts are highly desireable for Vintage MX racers so none are usually inexpensive.
~JM~
WWW.CADDY500.COM
The High Performance
Big Block Cadillac Forum
PostPosted: Tue Oct 11, 2011 9:32 pm
If you're just tinkering around and don't have some special project in mind, Don't Convert: Unless you have a problem with the existing bike and you can't get replacements for the right price or at all. If you want a CR, it will be cheaper and better to get a CR. If it's a unique project you want, then go for it!
My vote would be to go the OEM (or clone) route. Probably cheaper and easier to sell if the day comes.
nola_fiddy
1979 cr125r
Users browsing this forum: No registered users and 10 guests
