It is currently Sun Aug 17, 2025 6:06 am
 Post subject: CR125 CDI Voltage
PostPosted: Fri Sep 03, 2004 8:05 pm
Does anyone know how much voltage, (DC) should come from the CDI unit to the coil when it is kicked over? I am reading about 3 volts, which seems a bit low for the coil to step it up. The stator seems to be pushing plenty of AC up, so is my CDI DOA?
PostPosted: Sat Sep 04, 2004 8:52 am
Did you use an oscilliscope to measure the 3V?
I don't have a CDI in my Honda, just points/coil. I do have several bikes with CDI and it is more like a ~200V zap to the coil then a sustained voltage.
If you measure the coils primary and secondary resistance I can do one of mine for comparison.
Just drifting a bit. I looked up CDI in the US Patent base. They are a relatively simple design in their lowest common denominator. Just some AC to DC retification, a sensistive gate SCR<similar to the silicon found in light dimmers> and the equivalent of a photo flash capacitor. I ended up making my own albeit w/o any advance or other nicities for a Suzuki.
 Post subject: CDI
PostPosted: Sat Sep 04, 2004 11:38 am
I just used the old Radio Shack special voltmeter to check if there was any juice there. I am going to pull a CDI from one of my other CR's to see if it helps, possibly a coil also. Thanks for your input!
 Post subject: CDI
PostPosted: Sat Sep 04, 2004 2:53 pm
Yup! Bad CDI. I stuck another one in from one of my running bikes, and low and behold plenty of spark.
Thanks!
Users browsing this forum: Google [Bot] and 16 guests
