It is currently Thu Jun 19, 2025 7:33 am
 Post subject: Honda CR250R 1978-1980
PostPosted: Fri Aug 24, 2012 6:51 pm
Anyone using a DG-style swing arm and if so are you using the stock chain adjustors. The DG axle plate is wider than OEM and therefore the adjustor travel (and therefore chain adjustment) is limited. How did you work around this problem. I am thinking of having the slot where the axle sits machined a little deeper....
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 32 guests
