It is currently Thu Jun 19, 2025 1:30 am
PostPosted: Fri May 10, 2013 3:02 pm
Hi, my CR125 restoration is almost completed. But I have a problem for the throttle. I don't have the original throttle of the bike. So I bought a MotionPro and another jobber throttle but I have hard time to find a cable that work with those throttle and the original carburator.
Is there a throttle and a cable that can be installed without need to build a custom cable?
If I can't find one, I'll buy a cable an some nipples and build one but if someone know a kit that work right of the box, it will save the trouble of making a custom one.
Thanks!
1974 Honda CR125M - 1977 Honda CB750 - 1982 Yamaha XT550 - 1986 Honda TLR200 - 2016 Honda CRF1000L Africa Twin- 2012 Ossa TR280i
PostPosted: Fri May 10, 2013 5:49 pm
I use an '81 RM125Z throttle cable, P/N 58300-40X03 or 58300-14110. This is with an early 80's Suzuki RM right-angle throttle setup so who knows if it will fit your units, but I can take measurements if it will help. The critical specs are the cable length from the upper cable adjuster to the throttle rotor cable-end cutout, and adjuster thread size and pitch.
PostPosted: Fri May 10, 2013 6:59 pm
Hi Ray, do you used this cable with a RM125 throttle?
I need a throttle and a cable that will work with the Kehin carb.
PostPosted: Fri May 10, 2013 7:18 pm
Here's what I'm using now:
'82 RM250 throttle assembly 57100-27C00 or 57100-14301 or 57100-14302
'82 RM250 throttle grip 57110-27C00 or 57110-14300
'82 RM250 throttle rotor 57114-14301
'82 RM250 left grip 57211-27C00 or 57211-40201
'81 RM125Z throttle cable 58300-40X03 or 58300-14110
PostPosted: Sat May 11, 2013 5:50 am
Thanks, I'll look for those parts!
Users browsing this forum: Bing [Bot] and 30 guests
