It is currently Sat Jul 12, 2025 11:46 pm
PostPosted: Sun Aug 24, 2014 6:21 pm
The same gas mixture in my 125 smokes like normal. The 250 leaves a smoke cloud trail. Someone said it may be the right side crank seal. Any ideas?
PostPosted: Wed Sep 10, 2014 8:06 pm
That would be a good bet.
PostPosted: Fri Oct 24, 2014 12:03 am
Check your crank oil level. if the seal is bad, you should be losing oil. Also, the smoke will smell different than two-stroke oil burning.
Users browsing this forum: Majestic-12 [Bot] and 28 guests
