The OEM ignition timing is 20.5° / 1.94mm BTDC. If the timing is set correctly, the F mark (the line, not the F itself) should line up with the pointer on the inside of the ignition cover.
If you use the timing procedure in the shop manual, bear in mind that the light will always be lit, and will get slightly dimmer (the manual calls this "dark light") when the points open.
_________________ '74 CR125M (175cc), '75 MR175, '82 RM250Z, '08 YZ250F, '14 Zero FX electric, '14 Zero MX electric, '18 Alta MXR electric
