It is currently Wed Jun 18, 2025 9:09 pm
PostPosted: Tue Sep 22, 2015 7:34 pm
If your a lover of 74 CR250 then you should know the answer to this.
What are all the points that yellow marker paint was used on CR250 coming from factory.
I'm aware of rear axle nut and swing arm nut and did see one bike with the nut on the brake stay at brake plate.
Any others.
R
PostPosted: Fri Sep 25, 2015 6:08 pm
Both ends of the brake stay (bolts). Swing arm nut. Brake pedal pivot bolt. Rear axle nut. Master link and primary sprocket bolts.
Send me your email address and I'll send you some pics if you want.
1973 Honda Elsinore CR250M
PostPosted: Sun Sep 27, 2015 5:02 am
Excellent.
Good one for the records here.
Rob
Users browsing this forum: No registered users and 47 guests
