It is currently Wed Jun 18, 2025 9:12 pm
PostPosted: Sun Jan 03, 2016 8:09 am
I have a 1980 Honda CR250R with a very hard clutch pull. I have new cable and I have checked for binding on cable and lever. Bearing seams good on clutch rod in engine.
Any ideas? Is this normal for this model?
73 Honda CR250m
74 Honda CR250m
75 Honda CR250m1
76 Honda CR250m1
80 Honda CR250R
79 Yamaha YZ250F
79 Yamaha YZ400F
74 Yamaha GTMX80
75 Honda MT250 x3
66 Honda CA77 305 Dream x2
67 Honda CB77 305 Super Hawk
2009 Yamaha YZ250 2-smoker
2008 Honda CRF150RB
PostPosted: Wed Jan 13, 2016 10:37 pm
I wonder if the fingers are worn that hold the fiber plates in place. Those fingers should be flat but over time the plates can wear grooves at every plate, that can be 6 or 7 indents on each side of each finger.
If you have this try a large flat hand file. Position it so you remove these grooves on the front side AND back side on each stroke at 180 degrees from each other. Take your time and you will be good. I have done this many times on many bikes but it may only work one time per basket.
Rick
PostPosted: Fri Jan 15, 2016 6:40 am
Thanks Rick, I normally do this to every bike I build but on this occasion I bought the bike supposedly race ready. So I will go thru the engine to see what I actually have and polish all moving clutch components and file the basket as you suggested.
73 Honda CR250m
74 Honda CR250m
75 Honda CR250m1
76 Honda CR250m1
80 Honda CR250R
79 Yamaha YZ250F
79 Yamaha YZ400F
74 Yamaha GTMX80
75 Honda MT250 x3
2008 Honda CRF150RB
PostPosted: Mon Jan 18, 2016 2:25 pm
there will be a problem to file the basket.
if your basket is worn there will be no harder pull at the clutch lever. you get other problems.
maybe the preowner intalled stiffer aftermarket clutchsprings.
i tried them once, they are not neccessary and very hard to pull.
PostPosted: Fri Jan 22, 2016 7:55 am
It was the simplest fix possible ,the cable. I was told that all that was new but upon further inspection not so. Now just wondering what other surprises lay in wait for me.
Two or three races ought to reveal more secrets.
73 Honda CR250m
74 Honda CR250m
75 Honda CR250m1
76 Honda CR250m1
80 Honda CR250R
79 Yamaha YZ250F
79 Yamaha YZ400F
74 Yamaha GTMX80
75 Honda MT250 x3
2008 Honda CRF150RB
Users browsing this forum: No registered users and 44 guests
