It is currently Sun Aug 17, 2025 10:00 am
PostPosted: Tue Jul 06, 2004 9:57 am
I have a 74 Elsinore CR250M, with the stock 34MM Kehein carburetor. I'm having problems with replacement parts, so I'm considering getting a new carburetor. What performance changes would I see if I downsized to a 32mm, or upgraded to a 36mm.
Would I need to make modifications to accommodate the larger/smaller carb fit the bike, or are all carbs basically the same size.
74 CR250M, bought new in 74, still stock, except for the new 36mm Carb, and proform exhaust.
PostPosted: Tue Jul 06, 2004 11:10 pm
In very general terms, a larger carb gives you more top-end at the expense of bottom-end (and vice versa)...For instance I believe DG and Fox did 38mm carbs for CR250Rs that used 36mm carbs as stock. You may be lucky and find that the difference in bore is accomodated in a common body size and you do not need to make changes to your air-box and cylinder rubber boots. I think your biggest challenge will be re-jetting and it would be very useful to find someone who has done this before and can give you a reference point. Going back to your original problem, what is it that you cannot get for the stock carb, and have you contacted Sudco? (http://www.sudco.com)
PostPosted: Wed Jul 07, 2004 9:48 am
I've purchased 3 different repair kits. Each kit contained the same needle seat, and needle valve. Honda part number 16011-357-004. the problem is, they do not fit my carb. I've even tried a repair kit for the 73 model, they are just a hair too large. The bike still has the original stock Kehein carb from when I purchased the bike new 30 years ago, (yes that's a scary statement). I'm reluctant to continue buying repair kits, when I'm 0 for 3...
Last night I took the bike to a local rider who rides a 80 250 KTM in the vintage 40+ class. He had previously built a 73/74 Ellsinore to get into the vintage movement. He thought he had the carb from that project , but the one he has is a little smaller then mine. He made a few phone calls, and thinks he's located another Kehein carb from a CR250M. Its funny to see the looks on everyone's face when pulled up with the bike on the trailer. It definitely becomes a conversation piece when everyone begins to re-live their childhood as they had a similar bike, and or wanted this bike.
I was concerned that I'd have a problem making the carb fit, if I downsized or upgraded. Since the bike is 100% stock, I'll stick with the original size so I don't have to make any changes to the rubber boots.
Thanks for the info.
PostPosted: Sat Jul 10, 2004 12:02 am
Here is one on ebay.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... ename=WDVW
Rick
PostPosted: Sun Jul 11, 2004 10:48 am
:lol: Thanks Rick, I'm currently the high bidder...
PostPosted: Fri Jul 16, 2004 7:16 am
Just an update
I just received last night the carburetor purchased through e-bay, from a 73/74 Honda CR250M. Since I've been going crazy wanting to get the bike going again, I installed it, and the bike fired right up. Since it was 10:30 PM, I only let the bike run for 5 seconds. (I don't want to upset the neighbors or the wife by riding the bike in the yard that late at night.) I will remove it today, and give it a proper cleaning. Then I'll take her out to the trails, and see what happens.
PostPosted: Tue Dec 28, 2004 7:41 pm
all that is really cool brough a big smile to my face happy new year keep riding!
