It is currently Sun Aug 17, 2025 11:01 am
 Post subject: plastics cr125r 1980
PostPosted: Thu Jan 06, 2005 12:30 pm
Hello,
we are restoring an '80 Elsinore cr125r, but it does have serious sun-bleaked plastics. Can anyone tell us what's the best way to get the original color a little back?
Thanx
 Post subject: Re: plastics cr125r 1980
PostPosted: Thu Jan 06, 2005 1:24 pm
marcello wrote:
Hello,
we are restoring an '80 Elsinore cr125r, but it does have serious sun-bleached plastics. Can anyone tell us what's the best way to get the original color a little back?
Thanx
PostPosted: Thu Jan 06, 2005 1:52 pm
I doubt that there is much you can do about the original plastic unless you rub it down and spray it with Tahitian Red paint. Or you can just replace it with replica plastic. Both are available from http://www.red-racer.com. I have heard that a heat gun on a low setting can get rid of white marks caused when you deform a fender in a crash, but in your case the UV in the sunlight has bleached the red dye in the plastic. Good luck!
PostPosted: Thu Jan 06, 2005 4:23 pm
Site Admin
Go to the CR Reference forum and read the Fixing "Stressed" Plastic Coloration.
You can also use a product called Plastic Renew. It's made by PC Racing. Do a search on the web to find sources. A lot of motorcycle shops also carry it. I've used it and it works pretty good. Just be sure to apply decals before applying the Plastic Renew.
