I just put a '76 tranny in my '74 and it now pops out of second gear when I pin it. I put in the whole gear set, shafts and shift drum/forks from the newer bike. When it pops out of gear the cogs ride up out of the slots of the gear it is to lock into and then the tranny locks up and kills the motor.
Is there something special to do when doing this conversion? My old gear set (another '76 set) did not use the center case gasket but the tranny bound up when I did not use the gasket on this set. The old set did not bind up like this but it did not always catch the up shifts to 3rd and 4th. I haven't tried all of the gears under hard shifts, just second. It seems to shift well but pops out under throttle...
Any ideas? I have another '76 set but don't want to use it unless I have to.
mailto:rampman@fmxramps.com
