Hello,
If you are actually getting water mixed in with transmission fluid (oil), than the only way this could be occurring is through the water pump seal and or clutch cover (the head gasket is irrelevant). To find out where it’s leaking (or better yet when it stops leaking), take the clutch cover off while leaving the water pump and the in-let/out-let hoses connected to the housing/pump cover. Plug the out-let hose (the one closest to the rear of the bike) with a small freeze plug, bolt or something so that it is sealed. Take the in-let hose and insert a valve stem from a car or truck wheel into it; you’ll have to take another smaller piece of hose or semi-hard tubing which fits sung over the valve stem and inside the in-let hose in a way that the in-let hose can be clamp air-tight around the valve stem (sealing the valve stem in - without closing the air passage). Now you can take an air pump (don't use a compressor!) and fill the system with air. Submerge the cover in some type of liquid and watch for the bubbles. Hopefully, with a little troubleshooting and repair, this will help you get back to a water-free transmission.
Be sure that you are using the correct impeller and mechanical seal; their part numbers are 19215-KA4-000 and 19217-657-003 (or 013/023) respectively.
Good luck,
Robert D. Hawes Jr.
Mesa, Arizona
