mitchie wrote:
Will a piston from another brand 175 work?? The Kawa KDX175 and KDX220 also had 66mm piston, but I'm unsure of pin diameter or other specs on piston. It appears all Yamaha 175s also used a 66mm bore and 50mm stroke the MR175 did, but--again--not sure about the height of piston above the pin and the pin diameter. I believe the MR175 had a 16mm pin diameter. If you haven't already, I'd call Wiseco for measurements. You can machine a piston to make it fit if it is close. You can also rebush the con rod top if another piston would fit but has a 14mm pin. Good luck. This has to be very frustrating.
Hi mitchie,
Thanks for the good tips.
Gary Starr posted a contact to Rick Horvat, whom I contacted. (Thanks Gary)
According to Rick Horvat, a PE175 (Suzuki?) piston may be be close enough to use (possibly with machining?)
He also mentioned that the MR175 engine is a "bored" CR125 engine of the same vintage, and can be retrofitted to a CR top end if other resources are exhausted....but I'd rather try to keep it stock if I can.
I still have a few leads on Wiseco pistons.
I guess I'm getting a bit old.
..and have a hard time to realize that a 1977 bike is "vintage."
I'm sure there must be other readers of this forum that have run across similar dilemmas, so I'll keep you posted.
Mike
