Technically the heat transfer properties of the chromed cylinder are better than an iron liner, hence the chrome finish being chosen in the first place. That being said, many engines came with iron liners stock, and I have good experience with both types of cylinder on the same '79 CR250R. In a National with an expert or Pro rider back in the day this might have been a make or break difference, but with a novice in a 5 lap vintage race? However, what I have noticed is that the LA Sleeve sleeve does not line up with ports well on the CR. One might expect a little mis-alignment that could be cleaned up with a grinder, but in this specific case something else is up. The '79 has a bridged intake port and the hole in the cylinder for the secondary port is significantly larger on all sides than the port in the sleeve. To be perfect the resulting step would need be filled in and/or the sleeve opened up some. So if you pass me, that's the reason right there.
_________________ Michael Stiles 1979 Honda CR250R Elsinore | 2006 Husqvarna SM510R | 2007 Service Honda CR500R-AF
