JBACE wrote:
Why are Race Tech and Eibach fork spring free lengths different than stock? How could a shorter spring work without making adjustments elsewhere inside the forks?
For example:
'81 CR450 Stock =
609mm
Race Tech =
444mm
'82 CR480 Stock =
525mm
Race Tech =
472mm
'83 CR450 Stock =
581mm
Race Tech =
472mm
Eibach =
510mm
I appreciate if someone can provide some insight.
Thanks in advance.
Oops! I had the years wrong. They should have been '81, '82, '83.
Michael - Thanks for your response.
That might be part of it, though the differences vary greatly and seem to be larger than what the valves can account for. It still doesn't make sense for the Eibach.
What if I were to fabricate and install a spacer to make up the difference?
