I am capable in most areas except the bottom end of the motor. After I bought the bike, I brought it home, put in some fuel, kicked forever, then finally push started the bike and it fired up. Rode it around my yard in 1st & 2nd gear, after I brought it back into the garage I tried shifting it through the gears and it would only go down into 1st and up into 2nd - would not go up into 3rd, 4th, or 5th - so I suspect some issues there. The bike leaks oil from the crankcase, so at this point I want to have the whole thing gone through and rebuilt. Keep in mind the bike is in pretty rough shape and has a lot of abuse and does not look like it was ever properly maintained. I have the bike torn down to the frame and am starting from the ground up on it. I would probably be better off buying one already restored at this point
As far as the rear shock, that is on the list and I have spoken with several people about rebuilding it - estimates anywhere from $ 175.00 - $ 750.00 so I am not quite sure why there is such a large spread in pricing.
Budget wise, I can afford doing whatever I choose with the bike - probably looking to keep my costs under $ 3000.00 for the project.
