It is currently Mon Jul 07, 2025 10:32 am
PostPosted: Wed Aug 22, 2007 10:11 am
1, how can I tell if my spare cylinder is of a cr 250 or a mt 250 they're both 1974
2, would a 1978 cr 250 rim fit my 1974 cr 250 hub thanks for any help Simon
PostPosted: Wed Aug 22, 2007 10:52 am
The MT intake uses two bolts and the CR uses four.
Good luck with answer about the rim. It may turn the thread into a definitive discussion on the price and performance of lacing a rim with new spokes and I could use them myself.
Rick
PostPosted: Wed Aug 22, 2007 8:55 pm
The '74 and '78 rims have different part numbers but they are both 36 hole
and the hubs on both years are essentially the same diameter (at least on
one side) and width so most of the spoke angles should be the same.
Only way to be sure is to get a set of '74 spokes and try lacing one up.
I laced a '74 Honda CR125 rim to a Hodaka SuperRat hub (big weight
savings) with no problems and those two hubs were different in every
respect.
