It is currently Mon Jul 07, 2025 10:14 am
 Post subject: Oil mixture?
PostPosted: Sat Sep 08, 2007 1:18 pm
I just got a '79 CR250 Elsinore... What mixture should I use for the gas/oil? 20:1? 32:1? I run my old 2-stroke outboard at 32:1. Don't like to smoke any more than I have to, and I've never had any trouble with it. What do you guys recommend? What did Honda call for originally? Thanks!
 Post subject: Re: Oil mixture?
PostPosted: Sat Sep 08, 2007 6:01 pm
My Clymer manual specifies 20:1 for all CR M's and R's 1973-1980. I have read some articles that seem to think that 32:1 is fine for all 2 stroke bikes. This is based on the advances in 2 stroke oils. I stick with 20:1 and get a little smoke until warm, but the plug reads fine.
Steve Amling
1976 CR 250M
1980 Yamaha DT100G
1980 XR 200
1981 CSR650
PostPosted: Sat Sep 08, 2007 8:29 pm
http://www.maximausa.com/technical/oilmigration.html
...based on this I run Maxima synthetic at 32:1.
PostPosted: Sun Sep 09, 2007 6:14 am
50:1 with castrol rs2 or motul800
no problems in 17 years
PostPosted: Sun Sep 09, 2007 1:53 pm
The richer the oil mixture, the leaner the fuel mixture is(more oil and less gas in each intake stroke). So, it it more likely for you to have lean burn problems,and overheating problems at 20:1 mix ratio than at 32:1, 40:1, or 50:1. I have run Golden Spectro 2 cycle for over 30 years and never had a problem at 50:1.
OriginalDirt
74 AMPI CZ125
73 CZ400
73 CZ250 Basket case.
72 SherpaT 350
75 Montesa King Scorpion
72 Rickman 125 Enduro
70 Honda CL70
72 Honda Z50
00 DRZ400E Baja'd
PostPosted: Sun Sep 09, 2007 5:17 pm
Well I ran it today at 20:1. A little smokey when you gas it but not bad at all. Less oil smoke would be nice, but maybe more research first. For now I'll stick with what Honda reccomends.
The bike wasn't running 100%... Kinda bogged a bit more easily down low and took a bit to get into power band sometimes. Sometimes starts 1 kick, other times take 3-4. Gotta thoroughly go through the bike.
PostPosted: Sun Sep 09, 2007 9:19 pm
My recently finished restoring my 79 KX250 and it ran a little sluggish at first but after running a couple of gallons of fuel through it the power band really came together.
Terry Moody #48f
3x 74 Honda CR250M Elsinore
74 Honda XR75
73 Honda QA50
78 Yamaha YZ125E
78 Yamaha YZ250E
78 Yamaha YZ400E
79 Kawasaki KX250
79 Honda CR250R
79 Suzuki RM400
80 Honda CR125
2x 83 Honda CR480R
98 Kawasaki KX250
