I have a 76 CR250M with a stock Keihin carb, and just put in some NOS air screws tonight and need to know what some starting points are. Somehow I had lost the smaller idle mixture screw for the Right side of the carb, and had been running it with one of a slightly different size I had pulled from a carb I had around from a 84 CR250R, until I could get the right screw. I replaced both this screw, and the larger Left side idle speed screw, but have no idea where to start the smaller screw at. My manual calls for 2 turns out as a starting point for the larger Left side screw, but doesn't talk to the smaller Right side idle mixture screw. The Keihin website isn't much help either. It simply says
Set idle speed to proper r.p.m, by adjusting the IDLE SPEED SCREW. Turn the IDLE MIXTURE SCREW or the AIR SCREW to for correct procedure, achieve highest speed and best response. The IDLE MIXTURE SCREW (FCR) controls fuel delivery to the idle port and the SCREW is located on the engine side of the carburetor slide. Turning the IDLE MIXTURE SCREW out will make idle and off-idle richer. Turning IDLE MIXTURE SCREW (CR, PWK, PJ, PE) controls the amount of air to the IDLE and SLOW CIRCUIT. This SCREW is located on the air cleaner side of the throttle slide and turning the SCREW out will lean the mixture and turning the SCREW in (clockwise) will richen the mixture.
One other question on this. Both screws originally came with springs to hold the screws in place when adjusted. The NOS replacement idle speed screw was in a Honda parts bag, with the proper part number Honda tag inside it, but didn't have a spring. It had a fine nut that threaded on the idle screw, presumeably as a lock nut to keep the screw in place. I had never seen this before. Is this correct or did I somehow get some counterfeit parts? Has anyone used the nut, or should I just put a spring back on the screw to hold it in place. BTW, the new screws were gun metal gray, and not the brass I am used to.
