It is currently Fri Jul 18, 2025 8:43 pm
PostPosted: Mon Dec 31, 2007 4:12 pm
Hi
Can anyone suggest the best way to go for a cylinder re-sleeve.My 78 elsinore has a terminal score-mark near the exhaust port and I was looking for the best way to fix this .Is a stock barrel still obtainable or can I find a wiseco or equivalent sleeve that will do the job.I know this is a basic question ,but I have noticed some re-sleeved & electroplated barrels for the 78 CR250 failing here in AUS.Thanks for any light shed on this subject.
PostPosted: Mon Dec 31, 2007 6:21 pm
G'Day!
The most logical solution that I have used is to bore the cylinder to the nearest oversize needed to cleanup the bore, and then have the bore plated. You'll get better cooling than with a sleeve and won't have to mess around with port alignment. Just stock up on some extra pistons and rings for your new bore. You might want to follow the advice given in an earlier thread about drilling a hole in the piston at the exhaust port bridge for extra lubrication cooling. Instructions for this operation were included with my WISECO pistons. This will likely save you some grief later on.
1978 CR250R
1980 CR250R
1980 ME360
1986 CR250R
PostPosted: Tue Jan 01, 2008 3:39 am
Thanks for the advice moto-recon, from all reports that is the best way to go.Happy New Year everyone......
PostPosted: Tue Jan 01, 2008 3:00 pm
A decent reputable engineering shop will resleeve and port out your cylinder for you.
I live in the UK so cant recomend anyone local to you but for approx £120 ($240) you can have a new sleeve.
This has got to be worth investigating.
From experience it IS worth looking at.
PostPosted: Sat Jan 05, 2008 10:49 pm
whereabouts in OZ are you - in Perth I can recommend a place. Had a new sleeve put in mine - cast - as I was worried re new plating and so far it works like a charm and still more than enough go for me. Makes it easier for getting pistons and rings also.
regards
Rossco
1974 Yamaha YZ360B
1977 Suzuki RM370B
1980 Honda CR250RA
PostPosted: Sat Jan 19, 2008 5:45 pm
Thanks rossco, I live in Mudgee NSW , Central Tablelands.You must of had all the dramas as well,(trying to find someone in OZ to electroplate cylinders PROPERLY).
