It is currently Fri Aug 15, 2025 2:54 am
 Post subject: Lighting coil for CR125M
PostPosted: Tue Jan 22, 2008 5:14 am
Hi,
Is it possible to install a lighting coil in a CR125M?
Thanks.
PostPosted: Tue Jan 22, 2008 9:40 am
You would have to replace the complete ignition with that from an MR175 or MT125. Both will bolt right on. Unfortunately they are points style ignitions. The MR175 ignition would be easiest to convert but hardest to find.
I don't think you can add a lighting coil to the CR125 stator. There are two coils on the stator already to run the ignition without any additional room for more.
PostPosted: Tue Jan 22, 2008 4:17 pm
Thanks for your quick reply. I wonder which 70's 125 MX bike can accept a light coil?
