It is currently Thu Jul 17, 2025 11:54 pm
PostPosted: Wed Mar 19, 2008 9:45 am
Hi I am almost reasy to reassemble my 75 mt250 engine. I was going to put in a 74 cr250 crank I have but when I took out the mt crank and measured it it was 8mm wider than the cr crank which puts the crank shafts 4mm further out than on the cr. I am assuming this will make it not fit properly. If anyone knows anything about this swap please let me know if its gonna work or not.
PostPosted: Thu Mar 20, 2008 2:53 pm
the wider crank is for the electrics.you can put the cr crank in but you wont be able to use your ignition or lighting you will have to use cr ignition or go electronic
hope this helps.just look at the lhs engine cover for both bikes als cr to mr there is a bulge in the cover mt/mr and flat on the cr
cheers
jimg
Jim Garvey
1x honda cr250m 1973 in bits
1x yetman triumph dirttracker
PostPosted: Thu Mar 20, 2008 5:29 pm
You are right about the lighting but the bearing races are set out 4mm further on the mt crank as the weights are thicker so I really think it would cause problems on the top end was. A mechanic told me the cr crank could move back and forth and possibly cause the wrist pin to crack the piston.
PostPosted: Fri Mar 21, 2008 2:36 pm
hi
i have a mr250 motor and i was told the crank would fit in my 73 cr but i would need to use the mr ignition and side cover.i didnt do this i fully recoed my cr250 motor.you could br right about the 4mm i didnt pull my motor apart.no it is spares for my 76 cr250.
Jim Garvey
PostPosted: Fri Mar 21, 2008 4:45 pm
I believe the MR250 crank might fit the 76 CR250M, but the 73/74 has a shorter rod than the MR.
