It is currently Thu Jul 17, 2025 11:46 pm
 Post subject: 79 cr125 case
PostPosted: Fri Apr 18, 2008 6:04 pm
just got my cases apart so i can send my crank to get a new rod put on with the case apart can see where some water been in the crankshaft area at the bottom there is a spot where it has been eaten away about a1/4 of an in. and almost 2/3 the way through the sealing area could i or should i get this welded an surfaced off are these case's aluminum or magnisium 79 cr125 thanks jd
 Post subject: Re: 79 cr125 case
PostPosted: Fri Apr 18, 2008 6:25 pm
The cases are aluminum. As long as some of the gasket surface is intact (for a guide), the damage can be fill weld and
ground good as new. After the repair, place a straight edge on the newly repaired gasket surface and check for gaps
with a feeler gauge. Try to insure a straight and even surface as possible and you should be good to go.
PostPosted: Sat Apr 19, 2008 10:04 pm
thanks for the reply dogger i'am going to getter dun! i would not like the gasket to blow out after i get it all together jd
