It is currently Tue Jul 01, 2025 3:14 am
 Post subject: 1980 CR250R speed??
PostPosted: Mon Apr 07, 2003 4:25 pm
Anyone know tips for getting the '80 CR250R to rev better and run like '78-'79s?? Reed changes or pipes to use???
 Post subject: Re: 1980 CR250R speed??
PostPosted: Mon Apr 07, 2003 4:27 pm
Try dropping your slide needle one notch. That is. Take the clip off the needle and clip it in one notch higher thus dropping the needle. Rev the engine listen if it sounds crisper and snappier... check for lean running after you do a chop test at full throttle when riding.
