It is currently Sat Aug 09, 2025 9:00 pm
 Post subject: 79 CR250 reeds
PostPosted: Sun Feb 28, 2010 10:04 am
Anyone running a V force reed valve in the 79 CR250? What year of valve do you use. I believe I read a post on here that the 87 valve will work without modifications. Thanks Terry
Terry Moody #48f
3x 74 Honda CR250M Elsinore
74 Honda XR75
73 Honda QA50
78 Yamaha YZ125E
78 Yamaha YZ250E
78 Yamaha YZ400E
79 Kawasaki KX250
79 Honda CR250R
79 Suzuki RM400
80 Honda CR125
2x 83 Honda CR480R
98 Kawasaki KX250
 Post subject: Re: 79 CR250 reeds
PostPosted: Sun Feb 28, 2010 10:42 am
You are correct.
PostPosted: Sun Feb 28, 2010 4:57 pm
you can use all reed valves from 78-01.
some yerars have 6 blades, some only 4.
i think you can use the v-force cause it fits into 480cc cylinders and 480 reeds are the same as 250´s.
PostPosted: Mon Mar 01, 2010 9:28 am
Thanks,
I just ordered a set of the V force 3 reed valves. Terry 48f
Terry Moody #48f
74 Honda XR75
73 Honda QA50
78 Yamaha YZ125E
78 Yamaha YZ250E
78 Yamaha YZ400E
79 Kawasaki KX250
79 Honda CR250R
79 Suzuki RM400
80 Honda CR125
2x 83 Honda CR480R
98 Kawasaki KX250
PostPosted: Thu Mar 04, 2010 9:53 pm
would a boysen rad valve from those same years work as well? Allowing for an intake replacement at the same time
PostPosted: Sun Mar 07, 2010 5:56 am
you will have problems with the carb. boot, it´s angled to the right side.
PostPosted: Mon Mar 08, 2010 2:03 pm
I was told that there's a spacer that I could run with the V force set up move the carb, back a little and it would help the bottom end power. Does anyone have more info. on this? Is it still avail.? T
Terry Moody #48f
74 Honda XR75
73 Honda QA50
78 Yamaha YZ125E
78 Yamaha YZ250E
78 Yamaha YZ400E
79 Kawasaki KX250
79 Honda CR250R
79 Suzuki RM400
80 Honda CR125
2x 83 Honda CR480R
98 Kawasaki KX250
PostPosted: Tue Mar 09, 2010 10:58 am
I have seen what you speak of the guy also sells a reed setup for the cr250m. The spacer he sells is supposed to increase torque but I have no idea if it does I also dont remember who it was sorry.
PostPosted: Tue Mar 09, 2010 11:15 pm
most likely you could use a TRX250R spacer, they are dime a dozen and im pretty sure they share the same bolt pattern as a CR. Lots of different lengths out there from 1/4" to 1/2".
PostPosted: Wed Mar 10, 2010 9:04 am
Moose Racing sells them.
PostPosted: Thu Mar 11, 2010 12:31 pm
Have anyone tried one? What thickness did you use? Thanks Terry
Terry Moody #48f
74 Honda XR75
73 Honda QA50
78 Yamaha YZ125E
78 Yamaha YZ250E
78 Yamaha YZ400E
79 Kawasaki KX250
79 Honda CR250R
79 Suzuki RM400
80 Honda CR125
2x 83 Honda CR480R
98 Kawasaki KX250
