It is currently Wed Jul 16, 2025 6:02 pm
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
PostPosted: Sat May 11, 2013 4:54 pm
Sounds like the rectifier is bad. Probably why the battery was bubbling. It should regulate when the battery is charged and stop current flow.
PostPosted: Sat May 11, 2013 11:25 pm
Should I get one used (http://item.mobileweb.ebay.com/viewitem ... 0688954252) or new?
1976 Honda Elsinore MT125
1990 Toyota Celica
PostPosted: Sun May 12, 2013 1:06 am
I dont know if they make them anymore. but here are 2 different part numbers.
31700-361-003 (stanly), 31700-361-008 (shindengen).
PostPosted: Mon May 13, 2013 12:00 am
Up next, the speedo. The cable was missing so I replaced it. Now, when I get above 10-15 mph? It makes a whining noise. It's sudden, and doesn't really change with speed. I have yet to test it for accuracy, will probably do that tomorrow.
1990 Toyota Celica
PostPosted: Mon May 13, 2013 3:02 pm
The speedo is accurate. I sprayed some wd40 into the unit and the whining is gone. Next order of business, the "mod" part of restomod. I want to make a luggage rack. Has anybody made one? I have a general plan, but I'm not sure whether I want to make one from scratch or modify a premade one.
1990 Toyota Celica
PostPosted: Mon Jul 08, 2013 6:54 pm
So I've lost spark. New plug, newish coil, flywheel is good, but the points have continuity when open. I figured that must be the problem. I removed them and when they're off the bike they don't have continuity when open. Then I found that the stator coils are grounded. It seems like they shouldn't be right? Do I need a new stator or maybe can I get new insulators? ( current rubber is fairly hard and cracked.
1990 Toyota Celica
Users browsing this forum: No registered users and 49 guests
