It is currently Wed Aug 13, 2025 2:06 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Thu May 29, 2014 10:45 pm
Nate,
Having 4 MR175's, I think you may be polishing a pig. After everything you will have put into this bike, you would be better served finding an old CR. At least then, It will be worth 3-5K, rather than $500 - $1,500.
That said, it is good you cracked the case. Having new seals are important. You don't want to be sucking in air, or even oil through a bad seal.
If you can, what every you can convert to CR is better. I believe Ray likes to use the CR gears. MR parts are getting real hard to find.
PostPosted: Thu May 29, 2014 11:04 pm
Ray is right on about the CR ignition. They aren't that expensive, but they make a big difference. Bear in mind that you will lose your lights with the CR ignition.
PostPosted: Fri May 30, 2014 6:05 am
Matt,
I agree about the CR parts - ideally, you'd want an MR motor in a CR frame, like my 2nd bike. I've been meaning to post an update on it, but just haven't gotten around to it yet. A lot of changes were made in the last two years. The other bike (MR175) runs great too though - the CR ignition really changed everything, before that it was fairly pig-like. :) I'm now running a gutted MT125 pipe, engmod2t porting, 175 psi compression, a 29mm carb, and a '77 MR175 gearbox on the MR, and engmod pipe/porting, 30mm carb, 190psi, and hybrid MT/MR tranny on the MR/CR, which is wicked fast now that the jetting's finally dialed in (CR ignitions on both). I never tried the CR gearbox, though I probably will in the reed motor I'm starting on this winter.
I try never to think about resale - too depressing. :)
Users browsing this forum: Google [Bot] and 10 guests
