It is currently Wed Jun 18, 2025 2:25 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Sun Aug 28, 2016 1:52 pm
Plug readings I found online, way rich to slightly lean:
PostPosted: Mon Aug 29, 2016 11:14 pm
Pull the insert silencer out and look into the pipe.
On mine I could see the opening quite plugged.
If I recall correctly it had 3 openings that were maybe 1 to 2 inches long? and a twist as it to create a venturi effect.
I used a plumbers torch for SEVERAL minutes to burn off the buildup.
The pipe needs to be off the bike and air needs to flow out the head pipe in order to allow enough oxygen in to keep the flame burning hot enough to burn off the carbon.
Take your time and do it right. Hopefully you dont have to cut the pipe open.
PostPosted: Tue Aug 30, 2016 8:38 am
Thanks Rick I've seen the post's and utube videos on burn out the exhaust my only concern is getting all the ash out or is it not a real concern.
Dave
PostPosted: Wed Aug 31, 2016 11:25 am
I dont know. IMO if you want ALL out either cut it open or look for new (doubtful).
I recall now that I used long drill bits and rods to help knock that dark matter off when heated.
PostPosted: Fri Sep 16, 2016 2:39 pm
Proper needle set for the 1975 MT250: 16012-358-034
Users browsing this forum: Bing [Bot] and 52 guests
