It is currently Sat Jul 05, 2025 12:50 pm
PostPosted: Mon Apr 17, 2006 10:32 am
Sounds easy when you read the manual??
Trying to change the front hub bearings and getting nowhere fast.
I simply cannot get enough purchase on the bearing edge to knock the old bearings out. I am hoping that if I can get the first one out then the spacer can be removed and the second bearing will be dead easy
I am using a thin punch and a hammer.
What tips have you guys got please??
PostPosted: Mon Apr 17, 2006 7:17 pm
Make sure you push the center spacer tube to one side as much as you can so you can get to the bearing. I use an old 3/8 extension about 10 inches long to pound on the bearing. Try hitting it at different angles too.
PostPosted: Mon Apr 17, 2006 10:17 pm
Try warming the hub too. It will expand faster than the bearing and make it a little looser...
