It is currently Sat Jul 05, 2025 7:39 pm
 Post subject: 1979 CR250 problem
PostPosted: Thu May 11, 2006 10:01 am
I just finished my project 1979 CR250 and started it up last for the first time last night. When it fired up, it totally revved out like the throttle was stuck. I shut it down and tried it a couple more times, with the same result. I’m sure I must have screwed something up, I just don’t know what. The throttle seems to be working okay, at least I can hear the carb slide moving when I work it. It has a new flat slide Mikuni on it from Vintage Iron. Any suggestions on what to check would be appreciated.
Restoring a 1979 CR250R.....
PostPosted: Thu May 11, 2006 12:47 pm
If the throttle slide is not stuck I would suggest you have an air leak - carb boot, base gasket, ignition-side crank seal etc. What did you touch?
PostPosted: Thu May 11, 2006 4:52 pm
Basically, I have touched everything. I had a shop tear down the engine so I could have the cases, head and cylinder powder coated. They put it back together with a new gasket and seal set. Boy, I hope it's not something there. That was a lotta work ago....
The carb to reed valve boot is new, so I should be okay there, unless it's not sealing right at the carb.
Would an air leak make it run that fast? The thing is screaming and I have to just shut it down so it doesn't hurt itself. I thought of an air leak somewhere, but I thought (hoped?) it wouldn't make it rev that high.
I think I'll do a little more investigation on the carb. So how do I check to determine if it is an air leak?
Thanks for your help...
Stink
PostPosted: Thu May 11, 2006 5:50 pm
Take it to a shop and have them perform a leakdown test on the motor
