It is currently Sun Jul 06, 2025 3:28 am
 Post subject: Fork Leg polishing??
PostPosted: Thu May 11, 2006 5:02 am
Guys
Whats the best polish or technique you have come across for bringing the fork legs up to a nice finish please?
I intend to race the bike and not show it but I dont want the forks to look dull and out of place compared to the other resto parts.
many thanks
PostPosted: Thu May 11, 2006 12:39 pm
Start to take the big nicks out with a small, fine file...Then go over the hole leg with strips of 240 grit, then 400, then 000 steel wool, then 0000 steel wool...Its pretty time consuming, but you'll get a close to factory look.After that I had them clear powdercoated.eL
1974 Honda CR250M
1979 Honda CBX SS
PostPosted: Thu May 11, 2006 12:49 pm
If the original lacquer is on the forks, before sanding remove that with Aircraft Remover. Blue can, white letters, bottom shelf in the paint section at Pep Boys.
PostPosted: Thu May 11, 2006 3:16 pm
I have good luck polishing AL after giving a wet sanding with 220# --> 320# --> 400# then just buff with some brown rouge on a buffer then followed with some mothers....this will give a mirror finish. after racing simpley clean all dirt from it and wipe it down with mothers as needed to keep the shine on it. I have had good results with a 4" buff wheel in a small benchtop drill press. I need to rebuild my forks here shortly once my bike becomes a roller again (trying to limit how torn apart it is at once) and I will give a write up on the process I use (granted I will be using a 8" buffer to do it)
1975 MT250
1975 CB550
1993 RM80 (for sale)
PostPosted: Fri May 12, 2006 4:56 am
Hi there,
I just did the fork legs on my '74 MT250. Here's what I did:
- I used a Dremel (rotary tool) wire brush to take off the rough stuff
- I then used 400 water paper with WD-40
- I then used 1000 water paper with WD-40
This gave me a dull finish which is all I was looking for. I guess I could finish it off with a clear coat, but I heard that it may yellow the finish.
Newfie
Newfie
1974 MT250
1974 MR50
1975 CB750F
http://spaces.msn.com/members/andrewmer ... photoalbum
