It is currently Sun Jul 06, 2025 3:08 am
 Post subject: MR175=MT125
PostPosted: Fri Apr 21, 2006 5:31 am
Does anyone know if the stator from a MT125 will work in a MR175. They look very similar and have one extra set of windings. Probably a dumb question, but Im grabbing for straws. I need a stator and coil for a 76 MR175 if anyone may have one. Thanks
PostPosted: Sat Apr 22, 2006 10:42 pm
On the MR, 1 coil is for the ign. and the other is for the lights. On the MT, the third is for charging system (I believe). MT doesn't use a battery so there is no need for the third coil. if your not running lights you dont need the second either. In my opinion (for what it's worth) put it in. Whatcha' gotta loose!
 Post subject: It worked
PostPosted: Fri Jun 16, 2006 11:20 am
Well for what its worth the MT stator worked in the MR. Pretty Cool.
PostPosted: Sat Jun 17, 2006 12:50 pm
I have a boat load of MR175 used stuff, will sell it pretty cheap if someone wants to come after it, I am in the Atlanta area. May even have a couple of new parts left, I sold most of it.
Sam Alexander
1974 Honda CR250M
1976 Honda CR250
1974 Maico MC440
1974 Maico MC250
1977 Maico AW400
PostPosted: Mon Jun 19, 2006 4:49 am
You wouldnt happen to have the Headlight assembly, speedo and cable, or the Tail light assembly? If so, would you be willing to ship? Thanks
