It is currently Sat Jul 05, 2025 8:08 pm
PostPosted: Wed Jun 28, 2006 1:26 pm
:D
75 CR125 How many pipe springs?
Trying to get my 75 CR125 restoration accurate.
Parts book and OEM manual show 4 pipe springs. 2 at manifold. 1 by shift lever. 1 by brake pedal.
Did they delete the spring by the brake pedal in 75 because all 75 pipes I've seen had only wire loops on them for the manifold and shift lever springs. No wire loop for spring near brake pedal.
Anybody knowledgeable about this???
Thanks.
 Post subject: 74-75 pipe springs CR125
PostPosted: Wed Jun 28, 2006 11:22 pm
My parts catalog & Microfiche show the 74 as having 4 springs. However my parts catalog only shows the 74 pipe & not the 75. My microfiche shows the 74 & list it as having 4 springs. It list the 75 as having 4 springs than lists it again as having 3??? Go figure.
Sorry didn't help much!
On my race bikes I use two on the exhaust flange (required) one under the pipe and a Dryer Hose Clamp wraped around the pipe & the frame.
My pipes don't move!
Good luck.
