Oil level? HELP PLEASE https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=1080 |
Author: | burkemotorcross [ Sat Jul 01, 2006 10:47 pm ] |
Post subject: | Oil level? HELP PLEASE |
in a earlier post i asked if anyone knew the correct way to check the oil level in the crankcase on a MR175. Do i just take out the check screw and add oil until it flows out ![]() |
Author: | mdlafferty [ Sat Jul 01, 2006 11:14 pm ] |
Post subject: | |
Yes it is full when the oil runs out the oil check bolt hole. Be sure the bike is straight up and not leaning on the sidestand. |
Author: | burkemotorcross [ Sun Jul 02, 2006 8:09 pm ] |
Post subject: | |
thanks again mdlafferly. without your help, my bike wouldnt even be running |
Author: | rossvickicampbell [ Mon Jul 03, 2006 2:37 am ] |
Post subject: | |
but don't forget it has to be warm and the oil has circulated otherwise you can put too much in? cheers Rossco |
Author: | Ianscr250 [ Mon Jul 03, 2006 7:49 am ] |
Post subject: | |
the rule of thumb with oil is that it comes to the bottom of the thread on the dip stick housing this alows for aproximatly a litre to be used in total if you fill it right up u will have to much pressure in the bottom end and this can cause problems with blowing seals |
Author: | Go4Ducks2 [ Mon Jul 03, 2006 2:27 pm ] |
Post subject: | |
Just trying to understand, but how would too much oil blow the seals? Where would the pressure come from since there is no crank pressure in the gearbox and wouldn't the crankcase vent tube allow escape for any pressure build up? Just curious. thanks garry |
Author: | Sam427 [ Tue Jul 04, 2006 7:32 pm ] |
Post subject: | |
Your are right, there is no pressure in the crankcase, it is vented. You could cause the seals to leak by over filling the case though, and it could run out of the vent. |
Author: | Ianscr250 [ Thu Jul 06, 2006 8:56 am ] |
Post subject: | |
Hi guys your right in saying any pressure is released with oil as it heats up the air space heats as well causing pressure within the bottom end most is released but dependant on how tight ur seals are wether the release tube is clear any build up ie dirt waste oils can block the vent tube i just believe to be safe as aposed to being sorry |
