It is currently Sun Jul 06, 2025 8:19 am
PostPosted: Mon Jul 03, 2006 2:44 pm
I got a 80 Cr250 that I'm putting new swing arm bushings,pins, bearings and caps and the frame swing arm bolt hole on brake side is a little wallowed out. How do you guys repair that. My plan is to weld in a bead to fill in and dress down to original size, my buddy says drill out and put in bushing, I'm thinking bushings would create more problems.
What kinda swing arm bolt play should be in the motor mount....little or none cause I got some, but looks nice and round.
Garry Mainer
#33m (retired)
Honda Cr250r 1980
Honda Cr250r 1980
Yamaha TY250C 1976
Arctic Cat 650 H1 2007
PostPosted: Tue Jul 04, 2006 7:26 pm
Your buddy is right, I fix them by opening the hole up, usually with a reamer and putting a bushing in, make sure it's nice and tight, then tig weld it in on the outer edges, basically just fuse the two together, no need to add rod, it makes a nice clean repair.
Sam Alexander
1974 Honda CR250M
1976 Honda CR250
1974 Maico MC440
1974 Maico MC250
1977 Maico AW400
PostPosted: Wed Jul 05, 2006 6:11 pm
Thanks Sam, my buddies gonne love this...he's right! He's got the TIG, I got the MIG.
Garry Mainer
#33m (retired)
Honda Cr250r 1980
Honda Cr250r 1980
Yamaha TY250C 1976
Users browsing this forum: Majestic-12 [Bot] and 24 guests
