It is currently Sun Jul 06, 2025 5:12 am
PostPosted: Sun Jul 02, 2006 2:43 pm
Hi, does anyone know of a good aftermarket chain roller for my 79 CR250R? Thanks, Joe.
Joe
72 Yamaha CT2
PostPosted: Wed Jul 05, 2006 11:50 am
This is covered in other threads. Most of the modern after-market rollers use a bolt that is smaller than the hole in the mounting bracket on the frame. Issue #2 is that if you are running an after-market swing arm it will pinch the chain against a stock-sized roller. I am currently running a sleeve of nylon washers over the correct-sized bolt. Sam Alexander says that http://www.jastco.com is coming up with solution.
 Post subject: Chain rollers
PostPosted: Wed Jul 05, 2006 3:08 pm
I have chain rollers and chain sliders for every model Honda CR from 1973 through to 1984. Email mailto:red_devil_racing@hotmail.com for prices.
PostPosted: Sat Jul 08, 2006 9:58 am
Hi everyone,
I am going to try and fabricate a chain roller using some after market parts out of a catalog. The problem is that I don't know what the outer diameter of the roller is. Does anyone know this dimension?
Thanks, Joe
Joe
72 Yamaha CT2
